I have a sailboat and I have three 12V AGM batteries wired in parallel. I need a battery charger to keep these batteries charged. Low power usage is a priority because it is running from a solar bank of batteries. I compared a Noco Genius gen5 3x and a Victron blue smart 12V 30A charger.
For a sailboat running on a solar bank where low power usage is the priority, the Victron Blue Smart 12V 30A Charger is the superior choice over the NOCO Genius GEN5X3.
Why not the NOCO GEN5X3?
The NOCO GEN5X3 is an excellent, waterproof onboard charger, but it divides its 15A output evenly into 3 individual 5A banks. Because your batteries are in parallel, you would need to connect all 3 banks to the same bank, or artificially split them up, which is less efficient and won't offer the fast, controlled recharge rate of the single, larger Victron unit.
The Victron’s advantages for your specific setup include: Lower Power Consumption: The Victron charger boasts up to 93-94% efficiency. Because it generates very little heat, it pulls only 0.5 W of power when idle/in storage mode. In contrast, the NOCO can consume up to 220 W at full draw and consumes slightly more power just in general maintenance.
Smart Monitoring: Through the VictronConnect app via built-in Bluetooth, you can see exactly how many amp-hours are going into your batteries and monitor historical data on your phone.
Configurable Amperage: Since my 3 AGM batteries are wired in parallel, they act as one large battery bank. The Victron pushes 30A of bulk charging but can be manually throttled down via the app to 15A if your solar inverter is struggling to keep up on a cloudy day.
The Victron is better all the way.
Best sailboat battery charger - Victron Smart Blue IP22 versus Noco Genius Gen5 3x
roderick_richards@hotmail.com
- Site Admin
